Author: Subject: zetec ingnition
oadamo
posted on 10/6/07 at 06:31 PM Reply With Quote
zetec ingnition
is there a way of getting a zetec sparking with scrapyard parts because ive just bought some bike carbs adam
ps. iam a tight arse lol
meany
posted on 10/6/07 at 06:56 PM Reply With Quote
not done it yet myself...
http://www.toyne.org.uk/zetec.html
big_wasa
posted on 10/6/07 at 07:11 PM Reply With Quote
Have done it
You will need to attach a vacuume feed to the carbs. Easier said than done on bike carbs.
It will run but not give an ideal level of ignition advance for a tuned engine.
See http://www.youtube.com/watch?v=mwc6KwyhZ6g
[Edited on 10/6/07 by big_wasa]
Mal
posted on 10/6/07 at 07:21 PM Reply With Quote
Basic Zetec Running
When I had problems getting my car through the SVA test on FI I converted to Weber carbs and passed running the ignition on just an Edis unit. This operates the engine at a fixed 10 degee advance, but thr car would still do 80 mph.
I thing the control unit in the above reply, with a vacuum connection is an ECU from a 1.3 Escort of circa 1990, and may give variable ignition advance, as well as load sensing.
Mal
oadamo
posted on 10/6/07 at 07:22 PM Reply With Quote
Originally posted by big_wasa
Have done it
it runs ok tho and its cheap iam gonna upgrade later but i just want to get it running for now for as little money as possible lol
thanks adam
big_wasa
posted on 10/6/07 at 07:29 PM Reply With Quote
yes fitted to escorts and fiestas ect. It does in deed alter the advance with the load of the engine.
As cheap as it gets.
oadamo
posted on 10/6/07 at 07:39 PM Reply With Quote
if it runs ok ill leave it on. it will last longer then the engine anyway lol
adam
oadamo
posted on 10/6/07 at 07:44 PM Reply With Quote
do you have a wiring diagram for it
adam
big_wasa
posted on 10/6/07 at 07:49 PM Reply With Quote
you have u2
oadamo
posted on 10/6/07 at 08:04 PM Reply With Quote
you have u2
thanks wasa iam gonna go down tomorrow and see if i can find one. see if i can electrocute myself lol thanks adam
big_wasa
posted on 10/6/07 at 08:09 PM Reply With Quote
if you get stuck send me the loom and Ill alter it for you..
Dont think so some how..
Seeing your other handy work
big_wasa
posted on 10/6/07 at 08:11 PM Reply With Quote
you want to be looking on the near side wing and the back of the bulk head and you want the red and black esc as in my pic.
oadamo
posted on 10/6/07 at 09:03 PM Reply With Quote
thanks ill take off as much as i can then ill sort it out after
adam
