lsdweb
| posted on 24/7/07 at 11:07 AM |
Trigger Wheel
Hi All
I'm looking for a 62mm 12 tooth trigger wheel to fit inside my R1. I've been using an external trigger wheel but I want a more elegant
solution!
I've tried the ususal routes - eBay and http://trigger-wheels.com/store/index1.html but nothing doing.
I know they are available but can't find any!
I've found a 60/2 wheel in about the right size (in the US) but I'm not sure if this will work with my Emerald ECU (awaiting a response
from Emerald).
Any thoughts
Regards
Wyn
Agriv8
| posted on 24/7/07 at 11:28 AM |
Wynn,
would think Emerald will take a 60/2 input.
if not could you cut some of the teath off a 60/2 to make a 12 ? ( tyed doing the maths but gave up
regards
Agriv8
lsdweb
| posted on 24/7/07 at 11:40 AM |
Thanks Agriv8
Emerald will run a 60/2 wheel but that's a lot of small teeth on a very small wheel at 12,000 rpm! I was concerned that the sensor may not be
able to deal with it.
Trigger Wheels . com have been blindingly fast with their responses and are checking that their small 36/1 wheel is up to the job. FIngers are
crossed.
I don't want this to happen again!
matt_claydon
| posted on 24/7/07 at 11:49 AM |
Easy way is just to get a 60 or 36 tooth wheel and go at the spare teeth with the angry grinder ; )
| posted on 24/7/07 at 01:00 PM |
Leave every fifth tooth in and take the rest out, or every third tooth in a 36/1 should leave you 12 shouldn't it?
tks
| posted on 24/7/07 at 01:01 PM |
quote: Originally posted by lsdweb
Thanks Agriv8
crossed.
Man hey are you deaf???
i knew it wouldn't last!! you could hear it!
stopping would gave you atleast a longer day.
Tks
lsdweb
| posted on 24/7/07 at 05:30 PM |
What could you hear???
I lifted off and declutched as soon as it 'went' .
