Steve Lovelock
| posted on 12/12/07 at 08:51 PM |
MSnSE for Vx XE - settings required
Hello,
Having spent the past 4 or 5 months procrastinating I am definitely going to have a go at configuring my MSnSE and plumbing it into the XE engine
installed in my car. But, I would appreciate a copy of a similar set up if possible. You see I really don’t understand the manual and therefore
would appreciate a suitable reference point to start with.
If you have such a set up would you be kind enough to send it to me please:
steve.lovelock@tiscali.co.uk
Jenko
| posted on 13/12/07 at 11:47 AM |
Problem is - all installs will be different! -
Lets start with the fuel system - do you have a fuel injection tank (i.e. inbuilt swirl pot)?...if not then you will need a swirl pot set up, and high
pressure fuel pump / lines..........
Can I suggest you take each part of the project and break it down into tasks - Asking how to fit MS is a waste of time....just make a start and see
where it takes you........
I'm doing the conversion from carbs to GSXR TB's at the mo....
I've started with the high pressure fuel system, so I can fit it while still driving the car - once finished, it's time to build up the
TB's, then on to the wiring......
But with all these sort of installs - it does take time and allot of reading - Dave Walkers book on engine management is a good start point....
PJ.
daxtojeiro
| posted on 13/12/07 at 11:30 PM |
Hmmm, what dont you understand in the manual? I would love to know as I will alter it to make it more understandable. Have a look here for more info
on Alpha_n, http://www.extraefi.co.uk/MAP_Alpha_N.htm
Phil
