After being out of the driving seat competitively/track wise for 8 years or so I'm now hankering over having another go.
I've always fancied a 7 inspired car and probably now in the best position I've ever been in regarding owning/building one.
The biggest concern I have is I'm 6'3, 120kgs and with size 11 feet. Will I fit and be able to drive comfortably any type of 7?
I don't mind, in fact I quite like the idea of having to make a few adjustments (lowered floor/foam seat/taller roll bar/clip off steering wheel)
if required and putting my own stamp on something. Am I being unrealistic in even considering a 7?
Any makes better to look at or avoid in this area?
Thank you
The best advice I can give is go and sit in one but I would say you will fit knowing my son fitted in mine and he is 6ft 2 ins
Graham
[Edited on 13/11/22 by jacko]
I am a touch taller, a tad heavier and size 13 feet. Yes you can fit a book sized 7 with carful choice of seat and pedals. But comfortable. Maybe,
maybe not. I could manage an hour or so at a time.
There is a 3xl version of the 7 world where you can drop in and have bags and bags of room but they are no Racer.
Roll bar will need mods for racing. My head is above the roll bar, let alone a helmet.
Not my pic, if it even works but a Viento next to a Velocity.
[Edited on 13/11/22 by big_wasa]
I'm about the same size as you, and I fit in a Luego Viento with no great problem - it's a bit snug on the width, but plenty of legroom with
the seat right back. Of course it does depend on the exact car, what seats etc, but with a Viento you should be fine. I'll fit even better if I
lose a few lbs!
In contrast, before I bought the Viento I tried sitting in a wide body Westfield at the factory - I did fit in it, but really it was too tight for
comfort - the Viento is definitely better, if you can find one that you like.
I have a Locost built on the McSorley 442 plans. Loadsa room! Not tall - 5’8, but the seat will easily go back another 6-8 inches, and the footwell is wide enough for me to have a full false pedal alongside the pedal box.
Graham
The Luego owners club often had potential buyers asking to sit in Viento’s because they couldn’t fit in any other 7s . Suspect the club probably convinced more buyers to buy than Luego ever did?
Graham
I'm 6'4" and - ahem - getting rounder - had an MK Indy for 17 years. Seat is bolted to the floor rather than on runners to give a bit
more space, and it's a small steering wheel. Seat "hugs me" a little more than it used to when I first bought it, but that just makes
it more secure
I can't fit in a "standard" Caterham - and the MK, like many others, is bigger than a teeny-weeny Caterham - but it's doable.
Just try it, first.
same here, a bit taller and heavier and fitted into a couple of robin hood, (series 3 and a 2b) we used to always expect to do mods when we bought a
new one to get me comfy.
my last 7 was a locost with a fixed seat, build by a much shorter bloke than me, but somehow that just worked really well. (car was 6inches wider than
standard which helped) but event leg length etc was all fine with no adjustments.
there are a good few people out there of this size and so there will be cars built with this in mind.
also different seats with thinner backs and seat cushions can make a massive difference too.
[Edited on 18/11/22 by swanny]
