Hi
Looking for a gtir plenum if anyone knows of one for sale.
http://gti-r-us.co.uk/partsspares/
£45
Out of interest, why is the GTiR plenum the chosen option? Can the injected Zetec one not be used? Other than an adapter, is anything else needed to
boost a zetec? does it come with injectors and throttle body etc?
im still considering boosting my zetec so any infor greatly appreciated
What about one of these?
http://www.pepperperformance.com/rwd-zetec-plenum-chamber/
Or these
http://www.kitspares.co.uk/index.php?route=product/product&product_id=628
[Edited on 28/11/15 by Ugg10]
It is the simplest/cheapest way to do FI on ITBs that I'm aware of. Isn't restricted to Zetec as the backing plate/spacer will need to be
custom made. You can also use it with a single throttle body as well. When I did mine I was hitchhiking on what Flak Monkey has already done and it
was the choice between this or the Jenvey plenum at £600.
Not sure the other solutions would work with 1.4 or higher bar.
[Edited on 29/11/15 by jeffw]
£45
Nissan Pulsar GTI-R Throttle Body
Nissan Pulsar gtir inlet manifold thottle bodies sr20det
http://www.ebay.co.uk/itm/Nissan-Pulsar-GTiR-GTi-R-plenum-/111830454409?hash=item1a099d5089:g:7awAAOSwcBhWUZ59
[Edited on 29/11/15 by Ugg10]
