Hello
I have another question for you good chaps on here
I noticed tonight that when i turn the ignition on i have a symbol on my clocks for oil and next to it the indicator light.
They both flash together very faint in red
They seam to blip on and off 3 times then pause and repeat.
It does it if the engine is running or not.
Any ideas? is it a fault code or a short or something,doesnt effect the operation of the clocks.
Its probably a low oil level warning and low coolant temperature warning.
How far into the build are you? Have you had a look in the user manual?? Should be the same code as per the 98-99 R1 for which the manual is available
online (Page 348)
[Edited on 13/11/08 by Paul TigerB6]
The oil light is the level not pressure, and is on solid if the level is low.
Thanks guy's
Paul tigerb6 do you have a link to that manual?
The car is built and been SVA ed i bought it with a few issues which i have just about got sorted out now,infact this seams to be my last problem.
What should the normal running temp of an R1 engine be?
I wonder if the fault lights flash because it is not using the inbuilt water temp indicator,that always reads LOW however i have an racetech temp
gauge.
Could uit be that it thinks it is running a low water temp all the time and there for giving the fault.
