I am trying to find the efficiency (electrical power in vs light power power out) to work out efficiency of high power LED (aka emitter) so that I can
work out waste power dissipated.
So far not found anything in google - can you help?
That is your challenge for tonight!
[Edited on 21/11/08 by 02GF74]
not more homework
LEDs are usually quoted in candela - the amount of light in a cone. It makes them sound better because of the narrow beam they produce. Candelas are the number of lumens per steridian, a dimensionless unit of a cone. I believe there are 12 PI steradians in a sphere. In any case, lumens - the amount of light, is a form of power and Wikipedia or google will tell you how many lumens there are in a watt. About 600 or so. A bit of maths will therefore convert candelas to watts of light emitted. The rest of the power put into the LED will be heat.
special brew + homework = very low candela + hot sweats = low efficiency
Tee hee not very BRIGHT
[Edited on 21/11/08 by Bigheppy]
is this of any usefullness?
http://en.wikipedia.org/wiki/LED#Efficiency_and_operational_parameters
Vodka - im out!
this has been on my mind too recently as i need to make a VERY bright torch. I was torn between a non-roadlegal 100w headlight bulb running off a car
battery, or maybe a zenon bulb.
No idea about efficiency though!
Originally posted by JoelP
this has been on my mind too recently as i need to make a VERY bright torch. I was torn between a non-roadlegal 100w headlight bulb running off a car battery, or maybe a zenon bulb.
