Is it possible to modify HT leads and if so how?
motorbike ones can be moded and there are things you can do with car use like add SPITFIRE MULTISPARK ect as seeb forsale on ebay.FLASHING SPARK PLUG
CAPS ect .
[Edited on 10/1/09 by thunderace]
didn't you mean like changine the ends on them for different coils and stuff?
[Edited on 10/1/09 by blakep82]
not sure why youd want to "Modify" them?
I used to make them for a huge furnace where i worked once. We bought High Tension cable by the drum, and the ends and made them to length.
Yes I want to change the ends of on the plug side from Duratec to go into a Toyota
Since modern plug lead ends appear to be molded on , I dont think you will be able to remove/refit them - the custom lead set on my car (Mazda caps ,
Ford coil pack) cost more than the engine
i've got the same problem. vauxhall engine (twin cam, so its got those long plug leads) and ford coil pack. the vauxhall leads sort of fit the coil, but they're a bit wobbly, and don't seal well.
hi folks
go to a good bike shop, ngk do a good selection of plug caps.
graham
