Hi all,
Am on the scrounge - does anyone have the connector/wiring section which connects to the coolant temp sensor on the thermostat housing on a Silver top
zetec??
Beer tokens waiting..................
Chris
for gauge or injection?
you may find the standard ford ones wont work with aftermarket temp gauge and from bitter experience if using megasquirt,you are better off using GM
sensors than playing around with "not so easy therm"
Its for the injection (megasquirt). Are there some other sensors which fit the thermostat zetec housing and are easier to deal with??
Chris
