Luego Velocity Loom
mccsp - 8/3/09 at 11:45 PM
Hi,
Not sure if anyone can help or not. I have a loom which I believe may have originated from eliteloom. I believe it is a loom originally supplied by Luego.
Manufacturer Code: 060602
Serial Number: 0222
Date: 11th MAy 2004.
I bought this loom as a job lot from someone some time ago, when I first started building my car. Unfortunately there were no instructions and half the labels on the loom have fallen off. Does anyone have some form of wiring diagram or instructions that you may be of use to me. I am slowly getting to grips with the loom, but struggling on a few points. Any help would be greatly appreciated.
Regards,
Chris
In particular I am not sure what the orange and black wires do, and a little bit nervous about the ignition wire. Also the pink and white wires look like fuel pump and or ecu, are they man enough?
[Edited on 8/3/09 by mccsp]
chris_smith - 9/3/09 at 07:56 AM
iv used a velocity loom in mine, will try but cant get you a copy or pic of the destructions till weekend, i do kno though that orange and black are for the electric fan should be one into engine bay loom, and 2 into cockpit for the switch
if you need me to take a copy of the destructions let me know nearer friday or ill forget
chris
richwill - 9/3/09 at 10:27 AM
I have a copy i can forward to you tomorrow. I will scan it tonight.
Ive just finished my wiring and have sva on monday.
mccsp - 9/3/09 at 06:13 PM
Thanks,
If one of you could get a diagram to me that would be greatly appreciated.
