I need to extend my TPS wires. What size wire do I need and where do you recommend to get it from?
Measured with a set of calipers, the existing wires are 2mm external diameter.
I only need about 50cm x 3!
Cheers, Mark
Nothing special about them just use some suitable lengths from the parts of the Sierra loom going spare....
Just make the splices or connector are 100% ---- even a slightly iffy connection to a TPS can cause problems.
