Hi there all,
I am just changing from Webers to zx9r carbs, got them back form Boggs with manifold and fired up the motor. However I need to connect the zx9r TPS up
and need to identify which wire goes to which pin. Can any body help.
is the tps a 5v one, the wire on the left is normally the power feed, the centre wire is the signal wire and the right hand wire is the earth.
this method worked for me
link to previous post
Not sure what voltage the tps is but the one on the webers was a 5v. The one on the zx9r carbs is original to the carbs. Thanks for help chaps.
Thanks I have followed the links and think I can work it out now. Should be ready to take it over to Boggs. Cheers
