I'm looking for a relay for my radiator fan, I also have a big bag of relays.
The problem is that I can hardly wire a plug - how do I identify a suitable relay?
ta muchly
Chris
http://www.reuk.co.uk/Automotive-Relays.htm
Are you just looking for one to switch the fan through a dash switch? If so then a simple 4-blade one should do it.
linky to diagrams
Thanks chaps, I need one that works from the thermo switch and a dash switch.
Chris
chris fone me i have sent u2u will talk u through it
les g
If you're working on a switched ground for the relay activation switch, then just fork the connections - send one leg off to the temp switch and the other to your dash over-ride. Connect the other side of both switches to ground.
Thanks or the replies guys - I took the easy way out and got my Brother-in-law to sort it, all wired up now
Chris
