Ive just got my digidash2 lite wired in and when you switch on the ignition the display does a light show to presumably test all the lights etc.. then
it sits with the warning lights on?? should the lights go off or is there some thing you need to do in the digitools set up? not had a chance to plug
it into the laptop yet...
Ash
Mine turns all lights off after the test. Are you certain it is wired up right? things like the handbrake light, is that on when the handbrake is on and off?
