Amp Gauge wiring
madrallysport - 13/4/09 at 10:57 AM
Sorry for such a dumb question, but how to wire an amp gauge in, i can't get mine to work.
BenB - 13/4/09 at 11:04 AM
It's wire in serial. IE split the wire you want to measure the amps in, put on connector to one terminal, one to the other. Job done!
Mr Whippy - 13/4/09 at 11:10 AM
nitram38 - 13/4/09 at 11:18 AM
I think you mean series......
What it means is you go throught the ammeter with the circuit and through the load to complete it.
BenB - 13/4/09 at 11:39 AM
I do indeed. Always though serial and parallel made more sense though (that's my excuse anyway and I'm sticking to it!!)
britishtrident - 13/4/09 at 01:30 PM
Really best to try and avoid fitting an ammeter, these days with alternators doing the charging a voltmeter/batter condition gauge is the way to go.
02GF74 - 14/4/09 at 08:21 AM
I am with BT - don't bother.
the ameter will take quite large currents and ideally you do not want to introduce addtional circuitry or long wires in the charging cicuit.
a voltmeter will tell you if you alternator is charging; in fact the charge lemp will as well but on a much lower resolution.
[Edited on 14/4/09 by 02GF74]
