yes it could easily be done by using the handbrake switch...
the other accepted method is to use a seperate push switch on the dash to test the light. i had one of those on my old mini and my cortina. i never
felt the need to test the light though. so i'd never know if it worked or not.
a way to make the light come on automatically to test when you start the car would be ideal, sooooo
what if i was to wire mine into the starter solenoid circuit? that way whenever i push the starter button the warning light will test itself and come
on.
can anyone think of any issues with this?
Sounds ok to me. Your just using the same push button to start the car as you are to test the brake warning light
yep, and it tests the light every time you start up.
just thought the might be a reason why no ones done it before. like, do you have to be able to test at ANY time (inc when the engine's running)
but you can test when the cars moving really...
If you can arrange it you'll be fine according to both SVA and IVA wording - you may need a relay to change from switched live to switched earth
depending on your solenoid wiring.
IVA draft 3.2
The hydraulic system failure warning lamp must be secure,
operational, visible during daylight and darkness from the driving
position, identifiable (ie labelled in a recognised form – see diagram
1 for an example) and fitted with a “test facility” that enables its
operation to be checked from the driving position without opening
the reservoir.
i've not got any relays in the solenoid circuit, but given a bit of thought on the wiring front, it might work!
whats the point though? isn't the light test another of those things that are done just for sva and never needed again?
in which case i would keep it simple and use the handbrake, then there's no need for an extra switch that never gets used
Do it on the handbrake and you get a warning that the handbrake is on too.
although i'm sure we all do
the testing of the light is a safety thing. i'd rather it did it automatically than not at all. the way i'm thinking is the easiest automatic way i can think of.
i think this could work
obviously i meant to put the solenoid after to start button
i think you would need to use a relay there. the start button is switching live, you need earth for the light.
a savage start switch would work, use the other side of the switch for the light
Just to add another opinion to the mix...
If you are really dead set against using the handbrake switch (which in your case I can see the why) couldn't you just wire the warning lamp into
the same circuit as the alternator no-charge lamp (or even instead of it if you don't intend to have a no-charge lamp), this way the lamp gets
tested as soon as you turn the ignition on and will go out once the engine is running. This is, I'm pretty sure, how most production cars do
it.
D
Really would best to stick with the handbrake switch method
That would blow afuse if the float switch was closed and you pushed the |"Start button"
