where do i find a fuel sender and gauge that i can fix to my alloy fuel tank & can i use any sender with any gauge? jon
[Edited on 2/5/09 by jon b]
have a look at the RMD ones on rallydesign.com they're cheap but really good quality imo.
aside from RMD, they've got a good range of others too
You need the fuel sender that goes with your fuel gauge. You'ld be extremely lucky if any old randon sender gave meaningful readings on your
choice of dial.
Too many kit cars have fuel gauges that are JZ all use because of sender/gauge mistmatches...
I used the Racetech dial and sender. Cheap and good quality.... Depends on whether you need it to match your other dials and if so what they look
like.....
