Acewell tacho
austin man - 3/8/10 at 09:01 PM
I have an acewell fitte and running megasquirt the tacho appears to be reading too high I have set it at 0.5 I also have another tacho in line with this and this one reads too low. Could the problem be due to having 2 tacho ie signal being affected or do I need to adjust and output settings from the megajolt lite programme ??
RazMan - 4/8/10 at 08:16 AM
2 Tachos? I think they will be confusing each other - can you just try disconnecting one?
[Edited on 4-8-10 by RazMan]
