traction control / ABS sensors
rodgling - 10/9/10 at 09:43 PM
Hi,
I've bought a racelogic traction control box (yes, I know, they're for girls, I bring shame on real kit car builders, but it does give me the option for full-throttle-shifting joy) and don't much fancy paying racelogic £400 (!!!) for four hall effect sensors.
I could use regular ABS sensors but they'll be tricky to mount - the one advantage of the racelogic sensors is that they're on a long thread so can easily be adjusted to fit properly.
Can anyone suggest a generic position-adjustable hall effect sensor that might work? I've found this - anyone tried it, or something similar?
http://www.rselectronics.com/Catalog/ViewPart.aspx?Part=103SR13A-1&MFG=HNS&h=Sensors+Encoders+Position+Sensors+4.5+to+24+VDC-Digital+Posi tion+Hall-Effect+Honeywell+Sensing+And+Control
[Edited on 10/9/10 by rodgling]
rodgling - 10/9/10 at 10:27 PM
On further reading, hall effect detects magnetic fields, and the hubs aren't magnetic, so perhaps what I need is an inductive sensor? Maybe this kind of thing:
http://www1.conrad-uk.com/scripts/wgate/zcop_uk/~flN0YXRlPTI5NTIwNjM1NTU=?~template=PCAT_AREA_S_BROWSE&glb_user_js=Y&shop=UK&zhmmh_lf o=&zhmmh_area_kz=&product_show_id=155814&gvlon=&p_init_ipc=X&p_page_to_display=fromoutside&~cookies=1&cookie_n[1]=uk_inser t&cookie_v[1]=8V&cookie_d[1]=&cookie_p[1]=%2f&cookie_e[1]=Tue%2c+12-Oct-2010+22%3a25%3a54+GMT&scrwidth=1680
snapper - 11/9/10 at 05:54 AM
I had thought abot this sometime back, if you had a Sierra donor with ABS it has all the mountings, sensors and rings already there.
There are loads of cars in the scrapyard with sensors now, worth getting 4 from there.
Non magnetic sensors will need magnets, hall effects sensors will read off trigger wheels or bolt heads
rusty nuts - 11/9/10 at 08:55 AM
Getting ABS sensors out of old cars isn't always the easiest thing to do. Does your donor not use ABS?
paublo999 - 11/9/10 at 01:35 PM
I use 312-9564 from rscomponents.
You will need to add extra hub pickup bolts, I recommend no less than 6 pickups per rotation of a wheel. Abs systems use many more.
I still don't have my system working properly after a lot of work. Good luck with it and keep us informed.
[Edited on 11/9/10 by paublo999]
rodgling - 11/9/10 at 01:45 PM
It did (E36 328), but I'm using custom uprights, so ones where I can easily adjust the position of the sensor would help. And you're right, I only got two sensors out of the donor intact.
rodgling - 11/9/10 at 01:48 PM
Also, I've heard that ODBII cars (which mine is) detect the misfire and go into limp mode when the traction control kicks in, so I don't know if I'll be able to fit it after all... so I may have the racelogic kit up for sale soon if anyone's interested.
franky - 13/9/10 at 09:07 PM
Dave, I've had a check up on mine with the abs sensors out of the donor, got the rears out ok and they fit a treat on the abs ring on the drive shafts.... Managed to break the front trying to get it out but i'm 99% sure its a perfect fit in the pre drilled holes.
Great news as new sensors are only £14 and gives us 50 odd trigger points on each corner for the TC/launch control etc
