After taking apart my Volvo I cut off the sensor wires leading to the rear Diff as I assumed these would be for the ABS and/or traction light, but
turns out it is also the speed sensor for the speedometer.
I assume that this is probably just a normal magnetic sensor with a small magnet on the gear inside the diff, so really I could probably use anyother
speed sensor and mount a magnet on the propshaft or rear diff shafts?
Any ideas would be appreciated.
Thanks Mark
It will have been a hall effect sensor --- ie no magnets.
on a volvo it counts the teeth on the crown wheel.
uses the count for speed / abs / traction all very cunning.
