R1 5jj not charging guys I have swapped rectifier but no change rectifier does get warm to touch checked all earths any help appreciated
[Edited on 13/11/10 by big_l]
The stator burned out on my <- R1, to check it you'll need a multimeter.
Check the resistance between all three wires from the stator, they should all be the same, about 2 - 4 ohms IIRC, i.e. between any two wires.
Also check each one to earth, there should be no earth continuity.
[Edited on 13/11/10 by r1_pete]
Been and bought a multi meter but a little unsure wich setting it needs to be on !!!!
If this link works it should take you
to a download of a 98 R1 workshop manual, I think page 374 tells you how to check the stator and the required impedance.
tony
