Does anyone have an IVA safe wiring diagram?
eznfrank - 7/5/11 at 04:05 PM
I fell out with my loom recently and ripped it out of the car. I'd been trying to extend and add bits in but have decided to strip it back to the engine only bit and build a seperate loom.
So, I'm looking for an IVA safe diagram for me to work from. I actually thought about buying one of the CBS wiring modules (LINKY) but for £112 I'm sure I could build it myself a few times over - if I knew what I was doing......which I don't.
I think I need:
Indicators inc. hazards
Main beam - I don't recall if I need this or not but would like it as I have a hole in my dash with the switch already in it!
Dipped beam + tail lights
Sidelights
Fog
Fan + override
Horn
sdh2903 - 7/5/11 at 04:17 PM
I was in same boat seperate car loom for lights etc . I was lazy and ordered a uniloom from premier wiring. Its a good bit of kit but ive still had to remove wires for heater, wipers etc. If i was doing again i would definitly make my own.
Try having a look here for a diagram:
wiring linky
big_wasa - 7/5/11 at 05:59 PM
You dont really need one. Work out what you want perm' live and what you want switched live and stick in the fuse boxes. Work out how many relays you need and fit them.
Then just run one thing at a time holding together with masking tape. When there is nothing left, test and test some more, Its just a case of binding it all together.
snowy2 - 7/5/11 at 08:08 PM
easy to follow home made wiring diagram plus all you need to build it right,
http://www.andersensmith.freeserve.co.uk/wiringloom6.pdf
should sort it out for you.
