My starter motor is shot and I need to source a replacement
I can't see the part numbers due to the exhaust headers and heat shield blocking the view.
Before I strip it all down does anyone happen to know the Toyota part number I need to replace it? Its going to go on a 4AGE 20v Silver top.
I'm hoping I can source the replacement part fairly easily. Anyone got a spare they want to sell?
use this website, will give you all the part numbers you ever needed for a toyota
http://www.toyodiy.com/parts/q.html
If you are using the Toyota T50 gearbox and bellhousing you will need a starter motor from a rear wheel drive Toyota AE86 Sprinter which had a 16
valve 4age engine. Your Silvertop 4age 20v is from an AE101 front wheel drive which uses a different starter motor.
Toyodiy shows these numbers for the AE86 starters: 28100-15110 and 28100-15130. According to Toyodiy, the same starters were used in various 1981 to
1985 Toyota Celicas and, the case of the -15130 item, were also used in 1984 to 1989 Toyota MR2s.
Hope this helps.
Got the number now
ND 128000-2060
Next issue is do I go for a straight replacement on a smaller lighter gear reduction unit? Hmmm...
