starter diagram
mattv6cosworth - 23/10/11 at 11:19 AM
hi bought the car in my pictures as a none runner the car turns over but theres no spark at the plugs. the wiring is totaly screwed theres bits all over the place. has any one got a basic starting diagram or know the best place to get one from. its a 1.6 pinto not sure what year though cheers
Peteff - 23/10/11 at 05:27 PM
It depends which distributor and ignition system it has to which diagram it needs. Your best bet is to get an old Sierra Haynes manual.
snowy2 - 23/10/11 at 06:14 PM
if it is points ignition all you need to do is run a live wire to the +ve terminal of the coil and connect the -ve terminal to the distributor, if it is getting fuel it will fire.
