Hi All
I'm trying to find some multipin plugs and sockets and found the Cannon ITT APD range at Farnells, like
this but the delivery is £16!
I've hunted the RS site but can't find them - anybody know of other online retailers I can get these from?
Ta
Wyn
Try a search on eBay for "military connectors", see if that's the kind of thing you're after?
Most motor factors should be able to supply Durite stuff which may be suitable
door wiring conectors off a granada etc?
Wyn,
If you run out of options, I'll take a couple to help spread the postage if you like?
Thanks guys - I realised that a couple of small bits I'd stuck on to make the order up to the minimum £20 were coming from the USA and
that's what made the postage £16. Changed those for something in stock in the UK and free postage!
http://www.trigger-wheels.com/store/contents/en-uk/d10.html
3/4 of the way down the page. Mil spec style connectors. I used one of the 19way ones for the engine loom and while it isn't 'mil spec'
in its quality it seems very rugged and has worked well considering the money.
If you check Graham Blackwells site - Zetecinside
He uses RS Components plugs through the bulkhead, and give the link direct to the RS site - I think
If you want to go f1 then Farnell sell LEMO connectors for the job, and you won't have any problems getting over the postage threshold
Thanks for the pointers. Trigger wheels prices look good. IanK - a few LEMO connectors would cost more than the car !
Can you order direct from ITT Cannon? If so they are based in basingstoke so I could collect and post at cost.
