Where on the highstreet can you get split convoluted sleeving?
I only need a short lengh as have added a high level stop light and that is the last i need.
I can only find online sellers.
Halfords or other Car Audio place? Used in installs sometimes and is actually included in a lot of wiring kits..
Have tried Halfords, but will look around some more
Alternatively... how much are you after and what thickness? I'll check whether I've got any lying around
6mm inside diameter and about half a meter in lengh.
The annoying bit is I have about 8" of the stuff but not enough for what I want.
Then I have quite a bit left of the other sizes that I have used.
[Edited on 23/1/12 by Michael]
If you're stuck, VWP will sell you a metre for 63p here:
http://www.vehicle-wiring-products.eu/VWP-onlinestore/sleeving/sleeving.php
Unfortunately postage is £3.95 an VAT an additional 0.92 so £5.50 in total...
I'll have a rummage in the garage tomorrow night unless someone else beats me to it. Like you though, I think I've only got the larger stuff
left over along with some spiral wrap.
Craig.
Yes thanks Craig.
I have looked at VWP and Polevolt and have found the same prices.
The bay has cheapest at £2.39 for a meter so not realy worth the worry, but knowing its usualy 63p a meter then there is one hell of a mark up, but
that will include postage grrrrrrrr.
Just had a rummage - sorry matey, can't find anything other than 5-6" off-cuts so must've used it all!
No its ok, thanks for the look and unless you live in the garage, thanks for going out to look too.
I have a bit I could post you.
Maplins? RS components?
I've a load, its not split, I cut it if required. I'm in Kent (Tonbridge way) if thats any good to you.
