i have been looking and looking for a little denso alternator like the ones fitted to daihatsu's but just cant seem to find one with a pully of
the right number of grooves to match my early (mk1) silvertop zetec from a 1.8 93 xr2i fiesta
max i can find is 4 groove type and i need a 6 groove
also had a good look about for a pully to fit but i cant find one the right size denso's have a very short 15mm shaft
i did ring a alternator spechalist with a bunch of numbers of std types to fit std cars to see if he could come up with the goods and he came back
mega expensive as it was a new unit with a pully swap.
toyota and daihatsu units is what i have been looking at
idealy i would use a s/h one from scrappy but could go recon but at the end of the day it would be from a model of car.
its only going in a injected 7 kit so would want about 40A or more.
there must be plenty of users here with the baby densos so how did you get around the pully problem?
i know there is a few 5 groove types on ebay but thay are also expensive
im running the orignal type c/w coolent pump so im not driving off the back of the belt btw
[Edited on 25/4/12 by baz-R]
I know that this might be a bit left field, but,..... since you are only running the water pump and the alternator why do you need 6 groove,... I ask
as my 1600 has only 4 grooves on the belt.
The other alternative would be to buy the cheaper alternator and then ask someone to make a new pulley for you,..
hth
Originally posted by HowardB
I know that this might be a bit left field, but,..... since you are only running the water pump and the alternator why do you need 6 groove,... I ask as my 1600 has only 4 grooves on the belt.
hth
hth
i had been thinking of that but 5 or 6 would be a better option if it was availble?
good to know some 1600 run 4 grooves btw
