Hi all i need help with alternator i have followed this pic but the light stays on it will not go out any help will be much appreciated
You are using a bulb warning light not an LED ?
Yes the one like a spade end i am stump t i have only got to sort this and rev counter and all elec sorted
The wiring is correct, the warning light goes out when you get a balanced voltage across it Therefore if the bulb does not go out check to see what voltage is coming out of the alternator.
I am getting 13.9 volts its a Daihatsu Charade alt on pinto eng
Blip the engine and give it a few revs. Some alternators need a bit of a kick to get them going.
will give it a try thanks for all your help what is the best light to get as alt light
Will have a look for one on ebay thanks
