i have a fuel injected 4age with a emerald ecu and i need a dash so i was just wondering if bike clocks such as yamaha R1 can be used and if so i will
need some help with a wiring drawing etc
cheers
i have some busa clocks if interested. will cut you a deal if you need them.
Even if it will work, most bikes have analogue style rev counters. Will look a bit silly having a red line of 17k rpm and actually only revving to
about 8.5-9k
[Edited on 6/11/12 by pmc_3]
busas dont rev as high as the litre screamers
Might cost you a little bit more, but far more functionality & will fit without issue
[img]
Ace 6XXX
[/img]
[img]
Acewell 6556
[/img]
I'd be surprised if youcould "drive" a bike speedo with any accuracy from anything other than the original engine/box & transducer
- you know the answer - fit an Acewell!
They do 0 - 9000 & 0 - 15000 tachos as well.
