Hi Guys,
Like the title we are looking for a picture of the connections on the Sierra steeringcolomn, we are using the loom provided by the old Luego, we have
the buildmanual but can't really figure out where the wires go too, we connected most of the wires but are struggeling to get the brown and white
wires connected so we get a permanent live and get the indicators working.
So if someone can tell me where the following wires go to and which ones has to be joined than please.
- 1 thick brown cable
- 2 thinner brown cable
- 1 thick white cable
- 2 thinner white cable
Thanks.
What switches are you using ,you need the part number which is on the switch, there are at least 3 types of Sierra switches and at least 2 ways of wiring them. Use the search facility on here, Sierra switches have been covered several times. Can' help with the Luego loom , I used a Premier Wiring loom
