Alternator direction
jon200 - 30/1/13 at 10:22 AM
How do you know what direction your alternator is designed to run? I need to find a replacement smaller one but i am not sure the OE direction. Is it looking at the front of the engine crank pulley or from the rear of the alternator?
What size can i go down to Amps wise for a 2L turbo?
adithorp - 30/1/13 at 10:30 AM
Alternators run clockwise when viewed from the front same as most engines (with the exception of a few Honda's).
plentywahalla - 30/1/13 at 10:33 AM
I am fairly sure that they can run in either direction. The fan may not work so well though.
r1_pete - 30/1/13 at 11:58 AM
They can, and yes the fan needs changing.
Straight 6 E Types with Aircon had the alternator mounted the opposite way, pulley facing the driver, to fit the air con pump in.
mcerd1 - 30/1/13 at 01:12 PM
what else are you running off it ?
headed windows, geat big spot lights, electric windows, etc.... - or a track car no lights at and it just needs to start the engine
britishtrident - 30/1/13 at 01:36 PM
Fuel injection system takes a fair current but by modern tin top standards you don't need a big alternator 40 amps is more than enough. If you have carbs you can go even smaller.
jon200 - 30/1/13 at 05:10 PM
It's just starting and lights I'd need it for. Are there any the people use because they are small?
r1_pete - 30/1/13 at 06:44 PM
Nippon Denso from a Diahatsu Charade is a popular choice, sorry I never did establish the model number, but its running fine on my E Type.
40inches - 30/1/13 at 06:45 PM
A lot use A073 Daihatsu Denso Kit Car Lightweight Alternator | eBay
jon200 - 31/1/13 at 06:40 PM
That's pretty small! Will have a look out for a cheap one on eBay, have seen one but its from a terrios. Not sure if its the right one.
http://item.mobileweb.ebay.co.uk/viewitem?itemId=300851857134&kw=300851857134
[Edited on 31/1/13 by jon200]
