Hello, as a follow up on my other thread I have picked up a perfectly working e36 M3 Instrument cluster that I am going to wire into my Cologne 2.9
v6, mt75 4x4 with e38 rear diff. I would like to know if anyone has a wiring diagram along with the input voltages, currents etc. or if anyone else
has wired up one of these Instrument cluster, I can still swap the Instrument cluster for an E46 model if I can get better support for it.
These guys might be able to help you:
https://www.facebook.com/media/set/?set=a.326215047461492.73510.114076275342038&type=1
Southways Automotive down on the south coast.........
I have the E36 ETM (electrical training manual or something?) which includes cluster, engine and gearbox. Should be enough info to get you in the
right direction? u2u me on this one.
The E46 cluster is largely CAN controlled (whereas the E36 isn't). There are some project on the net which show moving gauges on diy electronics,
but it does seem a project in itself.
