Well.... Kinda given it away in the title, currently sat with head in hands.
Not running a screen so wipers are not needed.
But do need to know;
Which is live in?
Head,
Main beam,
Side light,
Indicators.
I'm fed up
Here you go:
Sierra Pinouts
or this one:
[Edited on 27/1/14 by Daddylonglegs]
Magic, that makes a bit more sense.
Think I need a new multimeter! It was giving a few weird readings.
Remember later spec Sierra switch gear is switched earth. Early type is switched positive.
You need to make sure you know which one you have got.
[Edited on 27/1/14 by Davedew]
Square hazard switch is on old direct switch gear
Round hazard switch is later switched earth that needs relays to switch big power stuff like the lights
