I don't have any lamps in my car at the moment and the flasher relay is just buzzing when I indicate or put the hazards on. Is this normal or is
the relay no good?
It's a 3 pin relay, does it matter which one I use?
Thanks Jon
Normal, you need the bulbs for it to work at all mate
I needs bulbs in to resist the circuit to slpw it down.
Dont worry, all normal
That's good then, one less thing to worry about. Thank you
