Hi Guys,
I'm installing a blacktop Zetec into my car and like a clever boy i wrote down a diagram of where all the plugs go!
Like a stupid boy, i've gone and lost it and now can't work out where all of them go!
So, if anyone can help with the following plugs, i'd be be very appreciative!
1. 3 pin on end of block connector:
2. 3 pin and 2 pin coming off injector rail loom
3. 4 pin round connector and 5 pin connector
4. 3 pin connector near ECU plug
5. Another 3 pin plug:
[Edited on 11/2/14 by pekwah1]
Mondeo or focus ?
"2. 3 pin and 2 pin coming off injector rail loom" 2 pin idle control valve 3 pin Tps
"3. 4 pin round connector and 5 pin connector" Round one is lambda other is gearbox reverse switch.
"5. Another 3 pin plug" as its near the oil pressure switch it could be the alternator plug. does it have a thickish red wire ?
I could probably tell the others from the wiring colour.
cheers wasa,
It's from a '99 mondeo "BASH"
Forgot to check the alternator, i'll have a look!
fond memories of doing the zetec wiring....good luck, with wasa's advice you cant go wrong....
