Hi I am wiring up hazard and indicator using durite switches. I have managed to get the hazards to work properly but the normal indicators run at
twice the rate they should be. Any suggestions on what I have wired up wrong or is there something else I am missing ?
Thanks for any help
do you have normal bulbs all round or some LEDs?
a normal flasher relay needs enough load to make it go at the right speed. if not enough - ie a bulb fails or led in place, then it goes faster.
Thanks for the info. I checked the front indicators and turns out that they were from a M/Cycle. Changes indicators and working ok now
Your help much appreciated.
nice one, glad it was something simple
