Hi there,
Does anyone know how this dash 'plugs' into the wiring loom?
Is there a housing that the 'prongs' at the top of the instrument panel plug into?
[Edited on 2/9/15 by JamesyCottony]
No just a set of plugs on wires
[Edited on 2-9-15 by ken555]
Where the flexible pcb sticks out at 90degrees, the loom plugs clip on to that projection.
[Edited on 2-9-15 by loggyboy]
So it looks like a normal plugs but clips into those pcb bits?
Also this is a 1984 Austin metro
got it thanks boys. So many wires
There is a diagram of the PCB on the GTM owners forum, if you need to trace the tracks.
[img]http://www.gtmdrivers.com/forum/download/file.php?id=1424[/img]
Thanks mate
POSTED TWICE SORRY!!
[Edited on 8/10/15 by JamesyCottony]
Originally posted by JamesyCottony
Found the perfect switches for lights!! AND HORN!!
look at this:
http://www.gsparkplug.com/durite-switch-rotary-push-off-side-dip-main-and-horn-bg1-0-645-70.html
On the first image I uploaded on this thread the top illuminated lamp is Main beam, the one under is side/tail lights, is there not one needed for
dipped beam?
