Hi all. I am trying to sort a long term issue I have with stability of the RPM on my Koso R1XN. I had always used the tacho feed to the old bike
clocks (having tried alternatives as described below), but it is not stable. So I am starting from scratch with the feed. The instructions state to
connect to the cylinder 1+ve side of the CDI/coil. On my engine (ZX12R) it looks to me like the coils share a +ve feed, and are then triggered by the
ECU switching the earth.
ZX12r wiring
Large wiring diagram
Is this correct? Please see the attached wiring diagram - should I be attaching to one of the red wires (labelled as Zundkerzen, at the top centre on
the German version of the wiring diagram I have!). I have had it set up to use the returning wire going back to the ECU from the spark, but reading
the Koso instructions, I think that this may be why I have been unable to get a stable RPM reading (as this is the -ve side of the coil). Help please
LCB collective!
[Edited on 10/4/16 by twybrow]
The +ve side of the coil voltage should normally show constant battery voltage apart from spikes.
The voltage on the negative side is the side the voltage will pulse on but because the ignition coil is an inductor in addition to the pulse at
battery voltage there is effect of the magnetic field collapsing which mirrors the ht tension spark voltage.
http://www.automotivetestsolutions.com/ignition-waveforms-tutorial-1.html
The cure is usually to fit a diode in-line in the wire from the coil to the tacho but
You could try this
http://www.hot-spark.com/tachometer-fix.pdf
[Edited on 10/4/16 by britishtrident]
The voltage on the negative side is the side the voltage will pulse on but because the ignition coil is an inductor in addition to the pulse at battery voltage there is effect of the magnetic field collapsing which mirrors the ht tension spark voltage.
You could try this
The pdf does show the connection on the positive side (mines negative as BT says) have you tried wrapping a coil of wire around the ht lead like it shows?
Just out of interest I connected my Owon Oscilloscope on the +ve of a coil pack on my tintop -- results pretty much as expected with the peak detect turned lots of on noise. After I turned peak detect off there was only battery voltage with a few mV drop each time the coil was pulsed.
Worth also trying the -ve wire on one of your injectors.
I was wiring in an innovate gauge that has a wire for RPM reading, the instructions stated that on an engine with CDI ignition, you could not use the
-ve side of the coil, and that an injector negative should be used instead.
That should hopefully sort it.
