One speed sensor - two uses?
Banana - 14/11/16 at 10:44 AM
IS it possible to split the feed from one speed sensor to supply the both Gear Indicator and SpeedoHealer?
adithorp - 14/11/16 at 10:58 AM
Yes, thats how it's usually done. Never heard of it done any other way.
Speedo healer is in series between the sensor and speedo and the gear indicator is on a spur either before or after the healer (pretty sure it doesn't matter which).
gremlin1234 - 14/11/16 at 11:12 AM
I would split it after the speedo healer, because that should be a much better defined signal
Banana - 14/11/16 at 12:39 PM
Great thanks.
Yes i was planning on splitting after the SpeedoHealer.
Banana - 21/11/16 at 09:59 PM
So its actually the speed sensor that came with the GiPro that i will be using.
Trust this will work for the speedo side of things? As i don't have the speed sensor on this old Blade engine.
So im going -
Speed sensor --> Speedo Healer --> Gi Pro (With signal split off to speedo)
Green black wire from Gi Pro --> Tacho Ylw/Grn or Pulse Ylw wire
Red and Black from GI Pro --> Live and earth
Someone correct me if thats wrong..
