Rover 200 Fan Plug.
r1_pete - 27/2/17 at 01:26 PM
I'm looking for a plug to fit this, does anyone know if its a generic part?? and better still a supplier?
Its from the Rover 200/400 air con fans...
nick205 - 27/2/17 at 02:18 PM
A quick Google suggests a Delphi AFU3306, but doesn't show a source for them.
Looking at your photo it looks as though you could use spade crimp terminals to connect to it. That wouldn't give a true connector appearance, but might achieve the electrical connection for you.
Other option would be to cut that connector off completely and reterminate with bullet connectors.
[Edited on 27/2/17 by nick205]
r1_pete - 27/2/17 at 03:18 PM
Yes a couple of 6.3mm spades will work, I just thought if I could get the proper connector.......
Itll be in front of the rad anyway so pretty much hidden...
nick205 - 27/2/17 at 03:24 PM
Understand what you're after, just looking for ways around perhaps not being able to buy the connector.
r1_pete - 27/2/17 at 03:29 PM
Cheers yes, appreciate the lead...
Ive got a name to search for now
nick205 - 28/2/17 at 03:31 PM
I've found Vehicle Wiring Products helpful before...
http://www.vehicle-wiring-products.eu/
...may be worth a call.
