I'm after some advice on a half decent fuel sender for my aluminium fuel cell.
Anyone got any thoughts?
I originally had a swing arm type but this proved to be in accurate and not great at below half tank due to the movement of fuel in corners.
I changed it to a tube version from the link below and everything is working well even on track
https://dmcomponents.co.uk/collections/fuel-senders/products/fuel-sender-for-square-or-rectangular-tanks
I use it with the stakk gauge like below, even though the Dash2 has the ability to display I use other functions and find the gauge easier to read cos
I don’t want to be the one who red flags a session because of no fuel..lol
https://www.demon-tweeks.com/uk/stack-professional-fuel-level-gauge-249500/
This gauge is good as you can set the ohm it reads
It also displays the fuel level last read when switched off which is really useful
I use it with the stakk gauge like below, even though the Dash2 has the ability to display I use other functions and find the gauge easier to read cos I don’t want to be the one who red flags a session because of no fuel..lol
It doesn't "have" to be anything but if you leave a bit of a gap it will leave yourself a reserve that you won't try to use normally
Interesting replies.
My point of view.
Gauge needs to be accurate enough at a sand still. If you are low enough to be worrid through the bends, you are already too low.
This doesn´t mean a wobbly needle is not an annoying thing.
Having your gauge read empty when there´s still fuel on the tang is like having your watch 10 minutes fast to avoid getting late to meetings...
I´d rather have my watch on time.
I bought my gauge/sender combo back when I had more "available car funds" therefore went for VDO. At that time I bought Water Temp, Oil
Pressure and Volt Meter, Matching Gauges - and senders. All else will be displayed through an Acewell unit.
Hope this helps.
