I was given a Robin Hood a couple of months back, the onlythign stopping it from being on the road is a lack of charging.
Pinto 2.0
I replaced the Regulator and rectifier with no improvement. A "New" one gave no charge either.
The space in the hood is tight a larger alternaor fouls the steering column.
Anyone got an idea on an easy fit replacemtn that's the same or smaller size?
Rob
one of the oddest failures in a lucas alternator circuit is the charge light / dash bulb. I suggest you check this before going any further ;-)
edit to add, lots of info on internet once you know what to look for.
ie:
https://www.theminiforum.co.uk/forums/topic/262248-alternator-problem/
[Edited on 20/9/24 by gremlin1234]
Photo of the back might help identify the problem.
ie:
