Caerbont Temp Sender Test
ChrisJ15 - 26/4/25 at 04:45 PM
Hi,
My J15 has had constant problems with the Caerbont temperature sender/gauge combination. It works for a while then decides to massively over read.
Has anyone got a range of resistance values I can use to check the (TT3001-8N) sender before I order another one please?
I did measure 54 Ohms at 80ish Deg C which is within the range for the sender (287-23 Ohms for 40 - 120 Deg C) but may not be correct.
gremlin1234 - 26/4/25 at 05:03 PM
check the earth, (chassis ground) engine to body to battery neg
[Edited on 26/4/25 by gremlin1234]
ChrisJ15 - 26/4/25 at 05:54 PM
Thats always been a challenge because its mounted into a plastic housing which means it has to bolt onto a connector.
This has worked OK in the past and its been taken off and cleaned up and shows good continuity to earth.
ChrisJ15 - 27/4/25 at 06:34 AM
One thing I noticed which was strange was that I get a different temperature reading with the ignition switched on but engine not running to when the engine is running (higher when running).
I had posted this same problem some years back and someone asked if I should be using a voltage stabiliser. I discounted this because there's nothing in the Caerbont instructions for the gauges for this.
gremlin1234 - 27/4/25 at 07:55 AM
this page shows some caebont gauges require a voltage stabilizer
https://www.smiths-instruments.co.uk/app/uploads/2024/08/PIL128-Bi-Metal-diagram.pdf
Mr Whippy - 27/4/25 at 01:23 PM
Those symptoms are very obviously voltage related
ChrisJ15 - 28/4/25 at 06:51 PM
I don't think the gauge (Caerbont ICT1-1452-01B) requires a voltage stabiliser.
The instructions that came with them were clear and showed direct connection to 12V via a 3A fuse with no mention of voltage stabiliser.
I've ordered a 500 Ohm potentiometer so I can test the gauge with the engine on and off as a starting point for diagnostics.
ChrisJ15 - 3/5/25 at 09:51 AM
To test whether it's the sender or the gauge I connected the 500 Ohm potentiometer in place of the sender and moved it through the range of my sender (287-23 Ohms representing 40 - 120 Deg C):
Engine off I needed 6 Ohms to get 120 Degress on the gauge and Engine running I needed 40 Ohms. Neither are correct (should be 23 Ohms).
The thing that stands out is I adjusted the potentiometer to get the gauge saying 90 Degrees with the engine off and when I started it it jumped straight up to 120 Degrees.
That to me suggests there's some internal voltage stabilisation in the gauge (Caerbont ICT1-1552-01B 52mm 12V Water temp) which isn't working. The voltages involved were pretty normal (12.67V off 13.87V running). The other gauges are the same spec and none of them are different with engine on/off.
So looks like I need another Caerbont temp gauge which is an absolute PITA because I have to remove the centre tub to get to the gauges and thats a big job, just when I want to be using it! I wasn't impressed with Caerbont before I fitted the gauges so should have used a panel to be able to remove them easily. Very frustrating!
gremlin1234 - 3/5/25 at 11:23 AM
or leave the gauge in place, and fit an external voltage stabilizer.
ChrisJ15 - 3/5/25 at 05:47 PM
I did think about adding a 12V to 12V Voltage regulator but they all show two wires in and two wires out. I could only intercept the positive going from he fuse to the dash area and not sure if the two negatives could be common.
gremlin1234 - 3/5/25 at 07:09 PM
common chassis ground should not be a problem.
gremlin1234 - 4/5/25 at 02:08 PM
to add, in this case, common chassis ground is ideal, but if you have canbus or other sensitive electronics, you should use an explicit 'ecu' ground.
ChrisJ15 - 4/5/25 at 04:19 PM
Thanks for the replies, no Canbus.
I think my approach will be. Buy new Gauge/Sender as neither appear to be working correctly.
Buy 12V Voltage regulator and see if this works temporarily, then when convient to take tub off change whole thing but retain voltage regulator (have had other intermittant problems with oil pressure gauge).
I did think perhaps the problem is having a small gel racing battery rather than a larger battery which would smooth out the voltage fluctuations more.
TimC - 9/5/25 at 10:55 AM
In my experience, Caerbont/Speedy Cables are brilliant to deal with. Have you spoken to them?
ChrisJ15 - 10/5/25 at 10:17 AM
Thanks but I already had a new gauge/sender and voltage regulator. I didnt think fixing would be wroth it when the gauge is ~£50 plus didnt want the car unusable for a period of time.
All fitted and seems to be working OK.
Did a few other jobs which had been waiting for the central tub to be off and then noticed the clutch master has been leaking into its rubber boot. Who said kit cars are never finished! That one can go into the list of 'things to do when front clam off'!
ChrisJ15 - 9/6/25 at 05:50 AM
Thought I'd update this in case others have the same issue.
I took central tub off, changed temp gauge and sender and fitted voltage regulator. tested this and all worked fine.
However, while the tub was off I had better access to some of the rear engine bay and noticed that there was another earth that I'd forgotten about. And it showed evidence of getting hot (discoloured stainless bolt). I'd been checking the earth from battery to chassis but the engine is mounted on metalastic bushes so theres another earth between engine and chassis! This bolt was threaded directly into the chassis box section and thread was a bit iffy so fitted a rivnut, created some bare metal around it and added a washer on top for good measure.
Think this was the source of quite a few issues and the starter spins much faster now.
So I have a new gauge and voltage stabiliser I dont need any more - but at least Ive found the problem!
Thanks all for your help.
