Hazard Warning wiring problem
irvined - 8/5/05 at 07:46 PM
Hello,
Fitted my loom this week, everything is going peachy, lights work, revs count (Although im on my 2nd dodgy reed switch for the speedo) etc etc, except the hazards don't work, when they are switched off, indicators are ok, when they are switched on, no lights come on, but the ignition circuit is live. (And the indicators no longer work.) Any idea what could be causing this?
Its a premier wiring loom.
CHeers
D
Hellfire - 8/5/05 at 11:28 PM
you've wired it wrong!
Sounds like yo haven't looped the feed through the switch properly...
Simon - 21/5/05 at 10:57 PM
Hellfire,
Thought you might like to know that I finally put brain in gear and followed your diagram (I had been trying to wire it up using the fuse box I got from Car Builder Solutions, so was having a load of aggro)
Anyway, we have success
I've been putting off sorting this for a while!!!
Cheers very much!!!
Simon
