having a Blond moment need help wiring
Savage fog light switch Please.
diagram shows
L.E.D cathode - =?
L.E.D cathode+ = ?
Common=?
N/O= ?
N/C =?
Not sure where they all go to?
Any help greatfully recieved.
Sean
This might help
Your a star thanks for the info.
Back to the garage now to install it.
cheers
Sean
Just finish wiring up and now works thanks.
I have seen these swithes light up when the lights are on how do you do that?????
2nd blonde moment of the day.
Sean
You'l have to feed the led '+' with an illumination wire from the dash lights,, grey i think if your using a premier loom
Jason
Oi, I'm an Essex blonde too ya know!
Just connect the LED pins (- to earth & + to side lights) That should do the trick.
Sorry Raz
Should we get the stilletos and hand bags out.
Only up the road from you near colchester should meet up sometime when the weather is hot all these great essex country roads to put down some
rubber.
Cheers for the help.
Sean
