Acumen BEC gear indicator
Moorron - 13/4/06 at 02:16 PM
The car i bought has one fitted but i am having great difficulties programming it, does anyone else here have one fitted to their BEC? i could do with some help with it.
It learns 1st and 2nd fine but it doesnt want to know 3rd and above. wiring looks fine on it.
help?
welderman - 13/4/06 at 02:30 PM
Is your speedo reading accurate.
R1minimagic - 13/4/06 at 02:55 PM
I have one, never been able to get it working properly. It learns all the gears ok but as soon as i rev past 2000rpm it loses them. Pretty useless....
Moorron - 13/4/06 at 08:54 PM
speedo works fine, alltho its on another proxi sensor its seeing the nodes a giving a signal fine, rev counter also works fine. wiring looks sound too.
good news someone had it working fine, it just seems the trend is that its not very good.
i do hit neutral between it learning 1st and 2nd and it learns then quickly, but i drove 3 or 4 miles trying different revs (and holding there for a while) and i gave up.
INDY BIRD - 13/4/06 at 10:15 PM
i did mine and found it easier to put the car on axel stands and run the car at around 4000 rpm works a treat saves all the hassle of driving on the road and concerntrting to get it wright.
i will say it finds it harder to get the gears wright at low rpm as it sometimes cannot differenciate the pulses at low rpm.
Moorron - 14/4/06 at 09:02 AM
i did it on axle stands originaly. But it still didnt do 3rd gear (at 4000 rpm). Might try it again and hold it at 9000 rpm. damn thing.
