Hi
I'm a little confused to where I should mount my headlights. Maybe someone could be so kind to let me know if I have interpretted the SVA regs
correctly?
As I understand it..........
Because the headlights i'm using (and most people are using) contain the side lights (also called front position lamps ???)as well as the dipped
and main beam lamps, then the position of the lamp unit has to conform to the 'angles of visibility' rules as well as the max/min height and
inboard distance rules?
Thats correct.
and its normal for them to be mounted towards the front of the vehicle pointing forwards and above ground level.
HTH LOL no use whatsoever I know.
Jos, haven't you got any work to do ?
Yeah, its helping a load of other kitcar builders with REALLY helpful comments like ^^^^^^.
You?????
