Bought an MGB wiper motor and assembly at a flea market, has three terminals, one marked earth, "Old" friend is worried it may be positive earth, and which terminal is Park. I am old enough to remember British cars with positive earth and damn 1/4 whitworth starter motor nut, but I don't think the MGB was one of them. Thanks
MGBs before 1969 were positive earth and later ones were negative but all the wiper motors are the same. They are insulated from the body so you can just wire it up accordingly. So my Dad tells me...
Originally posted by gazza285
But won't the wipers run backwards then.
Thanks for the info, so which terminal is park, and is there a built in resistor to get two speeds? Thanks again
Not if you look inside and understand how they operate.![]()
