r1 ignition question
zxrlocost - 1/5/06 at 09:58 AM
hi Ive stripped my r1 igntion barrel as I cant mount it anyhwhere and its got a right technical bit inside which joins certain things when you turn the key
Ive got a bog standard on off ignition from CBS
what I cant understand is it has 7 wires in there
but only 6 on the diagram
now 1 big red is deff + theres also a thick brown I presume is + when on and when ign is on joins these two together
the other wires seem to to switch together when ign is on
ie blue + blue/red
blue/yell + black
so is it just a case of buying three switches to join these then turning the igniton on to connect the big wires
only thing is the little wires dont seem to get there power from anyhwere
here is a link to the loom from mr chris mason
http://www.locostbuilders.co.uk/photos.php?action=showphoto&photo=1998%201999%20r1%20wiring%20diagram.JPG
thanks chris
