right i am trying to wire up the brake fluid warning light it is a ford type it has 3 wires 1 brown 1 brown/yellow 1 brown/green. I used the brown as
earth
and the brown/yellow as live(is this right) i know it is a good earth. I am take the brown/yellow to the live on the handbrake light on the
dash(live)but all is happening is blowing fuses Y?
As far as i Can remember, you just need the two outer conections on the tree pin conector
Hope this helps
Jason
EEK just re-read your post, 1 conector goes to earth, the other goes to bulb !!!!!!!
It's an earth switch, not a live switch
[Edited on 13/5/06 by Deckman001]
It's a switched earth.
what dose this mean?
The power runs through the bulb and then the switch. Rather than the other way round.
I posted how to do this a while ago!
Here:
http://locostbuilders.co.uk/viewthread.php?tid=39092
so are you saying it a live loop with no earth ?
U2U sent !!
Jason
